mperdue
Hi guys,
I've got a couple of general questions about SU carbs. They don't apply only to MG's but there isn't a general place to post so I thought I'd try here.
First, what is meant by "float angle"? I've seen 0degree, 20degree and 30degree carbs. Is that the angle the carb has to be mounted at to keep the float chamber level with the groung? Is this adjustable?
Second, does anyone know where I can find the bolt patterns for the HS4 (1.5" or 38mm) and HS6 (1.75" or 46mm) carbs? I need the manifold mounting bolt pattern, not the air cleaner side.
Thanks for the help,
Michael
edit: oops I took a closer look and there are general forums. can the mods move it?
Michael
