Peter Mittler
As some of you may know if you follow Skye's board my 81 MGB burned a couple of weeks ago. The final diagnosis seems to be that a float needle stuck and caused fuel to back flow into the two charcoal cannisters, whereupon it possibly filled the cannister and vapourized into a mist which was ignited by a spark from the ignition or possibly the heater fan motor which was on. Now I have purchased a 75 with the same carbs. Both overflow exits on the top of the float housing have no tube on them at all. This would mean any backflow goes onto a hot manifold. WHERE are these supposed to be 'tubed' to? I am not interested in any deja vue's and want to ensure the same problem does not re-occur. This car has only one canister and there is a open vertical stem on the canister which would apprear to be a place for a tube? I can post pics if it would assist. Others might like to check that there systems are correctly vented as well.
