SU Carb Help ......
George Zeck
I was able to spend some good time on my project during x-mas -- restoring a 64 Sprite that hasn't run in < 20 yrs. Replaced Tank, fuel line & added new electronic fuel pump. Also rebuilt both carbs with new gaskets / springs / rubber items where required. Car is in FLA and I am in OH and simply ran out of time to finish.
The next "step" is to run the power to the fuel pump & put the carbs on the car and adjust. From past links - I am aware of the need to put a "steel plate" to cover up the hole on the old placement. Run the power in "reverse" (Positive ground) -- pump is SU Pos & Neg from World Wide Auto. As for the SU Carbs .........
Any comments on the SU Carb's ?? I had the jets completely apart and replaced needles, jet's, and anything that was gasket or spring related. Also soaked in parts cleaner to get the "sludge" (formerly gasoline) off. How difficult is it. Any reading someone could recommend would be appreciated.
Tx-
George
gzeck@email.com
[ 12-29-2003: Message edited by: George Zeck ]
[ 12-29-2003: Message edited by: George Zeck ]</p>
spritenut
George
Run a white wire from the ignition switch to the fuel pump. White is the correct color on later Sprites. You could run it from the switched side of the fuse block too. (white or green wire side)
Might as well keep it correct.
On the carbs, make sure the jets are centered.
Loosen the large nut a bit, raise the piston (dashpot off) and let it drop, it should clunk.
Do this at the same time as tightening the nut incase id slips. there should ne no binding.
For an initial carb setting, turn the adjusting nut (5/8 wrench) 2 1/2 full turns down.
Or 15 flats of the nut. This is a good starting point. from there it should run, you can lean (tighten) or richen (loosen) the nuts as required
once the car warms up.
Who am I kidding, carb adjustments are a daily chore on SUs
I mean a tweak here, a tweak there, and when you think you have it perfect, the weather changes so you tweak them just a wee bit more.
Mickey Richaud
George -
Here's a great "how-to" for adjusting SU's:
Tuning SU's
piman
Hello Spritenut,
I was going to reply to your comment, but in stead I will quote what is written in the"Tuning SU's" link. Note the last sentence.
step 1- Tune up the rest of the engine- REALLY! clean or replace, and set the points, set the timing, plugs, valve lash, and remove the air filters (have new ones ready) All of these things can affect the setting of the carbs, which should be done LAST, (if at all). The carbs rarely need to be adjusted, once set.
Alec
Mickey Richaud
Well said, Alec. Once I got mine set, they have performed perfectly well (several months now).
Also, remember to keep the proper oil level in the dashpots. The stuff does "disappear" from time to time.
XK4
edit: Sorry, it is upset bovine!! After posting this, I read the post just above it and realized mine was un-needed.
It has been a long while so perhaps I'm having brain fade (or could it be "mad cow" or upset bovine??) but I thought one needs to put some light weight oil down the center of the piston under the large hex nut thats located up on top of the piston chamber.
As I recall the oil acts as a damper to slow the pistons rising during acceleration.
Am I wrong??
[ 01-01-2004: Message edited by: XK4 ]</p>
piman
Hello XK4,
no, you are not wrong, that is why the oil is there. There is a small piston attached to that nut and it's function is to stop the piston rising too quickly when the throttle is quickly opened which would then weaken the mixture. It is the same function as an accelerator pump on some fixed jet carburettors.
Alec
RGK TR5/TR250 SU carb ID help Triumph 6
jlaird MGB V6 carb help MG 14
P Carb Help - Car idle slows and dies after being run for a while Austin Healey 14
D Rough running BT7 3 carb HELP Austin Healey 13
I Spitfire 78 spitfire carb connection help Triumph 8
UmmYeahOk GT6 I Give Up! Help A Millennial Out [Carb/Choke Related] Triumph 28
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
K SU carb Help Spridgets 10
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
E Need SU Carb help Austin Healey 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
K Tri-carb help Austin Healey 11
K Tri-carb help please Austin Healey 0
R Carb help, where to find it? Spridgets 4
Spriteman65 Carb help Spridgets 11
7 Carb help needed Triumph 6
I TR6 Carb help please for 69 TR6 Triumph 14
I Help with carb hook up for 948 Bugeye Spridgets 8
M weber carb rebuild HELP! Spridgets 50
P Help with choking weber carb! Spridgets 2
tweety Help me verify what to check with the carb.... Spridgets 0
Morris Help identifying carb set... Spridgets 18
J Seeking tri carb help Austin Healey 16
I TR6 69TR6 carb adjustment help Triumph 5
vping I need some carb help. MG 8
mountainman TR2/3/3A TR3 Carb Rebuild Help Triumph 1
newmexTR3 TR2/3/3A TR3 Carb help - crazy idle Triumph 12
I TR6 69 TR6 carb tuning help Triumph 8
I TR6 69 TR6 Zenith Stromberg carb help Triumph 1
LastDeadLast Help! In need of HS carb parts Jaguar 9
LastDeadLast Help!! HS Carb Part needed Triumph 20
YankeeTR Carb ID help.. Triumph 4
martyc MGB Help: 73 MGB w/ Weber DGV Carb - Popping Downhill? MG 9
WidespreadPanic TR6 TR6 Weber Carb owners- a lil' help please Triumph 9
L Spitfire Help me make a carb choice [Spit 1500] Triumph 18
TR_JOE250 Spitfire Spitfire carb need help/opinions Triumph 6
I TR6 TR6 carb help Triumph 4
drooartz Carb help--idles too high Spridgets 7
R Carb leak help please Triumph 5
PAUL161 SU carb. problem. Help,Help,Help! MG 12
R6MGS Weber Carb Parts...HELP! MG 4
JPSmit Carb removal help Spridgets 5
George Zeck SU Carb Help !! ?? !! Spridgets 3
J SU HS6 carb need help Triumph 10
coldplugs T-Series Help! Carb, intake, etc.. Car wont start MG 6
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
