Andy Blackley
I bought one of them there Ignitors the other day. My question is can you do a static timing setting as with the points, i.e. set the static (10BTDC), hook up the test lamp, and rotate the dizzy until it the lamp lights up?
I figure this is a good time to pull all the plugs, check the valve clearances,retime as described with the Ignitor in place, and install new NGK BP6ES plugs set to say .030 ( I still have the stock coil.)
