I've got two problems. My turn signals work fine, but the green dash light doesn't blink, and my dash gauges have to lights when the headlights are on.
All else works.
From the lighting switch there are several wires, one of which is brown. It just hangs loose. My wiring diagram shows that to connect to a green and brown wire.
However, there is no such wire available to connect under the dash--that I can find. The only one which "might" have been available is already used for the turn signal switch.
Any ideas?
All else works.
Any ideas?
