6969ronin6969
Here's the history, I noticed my ammeter was reading negative one morning with the lights on. I figured the generator had finally given up, but took a look at the regulator first before pulling the generator out and having it rebuilt. While looking at the regulator I tried cleaning the contact points and adjusting the gaps to what I saw in the manual. That didn't fix it, so I went ahead and pulled the generator. After I got it back and installed I put it in and everything seemed good. Possibly too good as now the positive charge I could see on my ammeter was pretty high. I felt the need to turn on my lights just to keep from overcharging the battery. The next morning I came out and the battery was drained. My son (4) had been sitting in the car the day before so I figured he had left somethig on. I recharged the battery with a charger and drove to work the next morning. It was early so I use my headlights. With that situation the ammeter still showed a slight charging situation. When I cam out of the office in the afternoon, my battery was drained. This happened 2 days in a row. I thought the battery might be bad after getting discharged earlier so I took it back and got another one(was still in the replacement phase). Well, the next morning, the car was dead again. Until I the generator went I never had a discharging issue. I could let the car sit for a couple of weeks and comeout and she'd fire right up. The only other thing I had messed with in the system was the regulator. So I went back to that and started double checking my earlier adjustments. I could see where one of the contact points was touching, when cold, and adjusted this based on another period Lucas manual I came across that was specific to the regulators from this era. After sitting overnight the battery was not drained so that seemed to have fixed that problem. However now I don't appear to be charging the battery either. Could I have damaged soemthing based on the explination above? If I put a voltmeter on the battery while the car is running and rev the engine the meter does hold a steady reading of about 12.70V and seems to uptick to 12.71V if I wait a couple of seconds while revving the engine up to 2k rpm or so, but I would expect it to read higher, plus my ammeter never goes positive now, but it will read negative if I turn the lights on. Any ideas?
Thanks,
Eric
Thanks,
Eric
