Welcome to the Forum, Leavitt -
Assuming they're stuck due to corrosion, you'll need to soak them for a good while in PB Blaster/WD40/etc., maybe apply a bit of heat, and then VERY CAREFULLY pop the pistons loose with compressed air, through the port where the line connects. Be sure to wrap the cylinder in a thick towel to catch the piston, and be sure to aim the opening away from that window opposite the bench vise! WATCH YOUR FINGERS, and good luck!
/ubbthreads/images/graemlins/cheers.gif Mickey
