jcatnite
Last weekend, you may remember, I found timing chain tensioner chunks in my oil pan. This weekend I figured I would just pop the cover off and take a look inside...RIGHT!!!. I've just spent my 4th hour of trying to loosen the big nut on the crankshaft pulley. I've broken both my short and my long 1/2" drive breaker bars and one 1/2" drive ratchet. My 5' cheater bar is bent like a pretzel...not really but there is an impressive arc to it now. I know that I have to be getting at least 250 ftlbs on that sucker and it isn't budging. Before I started I soaked it for several hours with AeroKroil. So my question is how much torque can I put on this thing before I worry about pushing the side of the block out with the crank? I've gone through a couple of feet of 2x4 as well. My impact wrench is electric...don't ask why I ever though that was a good idea...and doesn't have that much umph to it...max is rated at 240ftlbs. I am considering buying this pneumatic wrench and am wondering what everyone thinks.
https://www.grainger.com/Grainger/productdetail.jsp?xi=xi&ItemId=1611776761
Should that be enough? It's really more than I can afford to spend on "fun" right now but I have to get Rusty back on the road. She looks pitiful in the garage sitting on jackstands. Also if there are any more suggestions I am wide open cause I'm at the end of my rope on this one. You know how once you've exhausted all your good ideas you resort to the ones that seem to just break stuff... that's where I am now...
Any help is greatly appreciated.
JC
JC
Hi Guest!
