TR4/4A Strombergs...wont idle unless choke pulled out?
karls59tr
Bronze
I realize that there could be many reasons for this to happen but what would be the most common one or the first thing on the carbs to check? All my experience is with SU's.
Geo Hahn
First thing I would try is increasing the idle speed with the two screw stops for the linkage.
On ZS carbs pulling the 'choke' does two things - slightly increase the idle (uses a cam) and slight lift the carb pistons (uses the start bar - a shaft with a flat on one side).
To set the idle I would first assure the carbs are balanced (adjust them w/ one of the screw/bolts on the accordion connector loosened) then tighten it up when they are balanced and the idle speed is good.
Beyond that there are many things you might check - timing (changing timing due to points wear or slipping), examine carb diaphragms, mixture, float level & float condition, etc -- IOW a complete tune-up.
But if the problem is simple and slight an idle adjust may get it done.
Has the car sat for a while and not run? The bass needles corrode very easy. Look and see if needles are green, if so clean with scotchbrite pad or fine sandpaper.
Marv
K
karls59tr
Bronze
Marv
Yes the car has been sitting for 10 years. I will clean the needles. How difficult is it to access them?
Karl,
not hard at all. There are four screws on top of the dome of the carb. Unscrew them, remove damper rod where the oil goes. Maybe tap domed upright with hammer to break loose the dome and lift it up. You will see spring and black rubber diaphragm. An old torn diaphram maybe your problem as well. Look for any tears in the seal. Gently pull on the upright pipe to lift it all out. Needle will be underneath.
Marv
glemon
Check to make sure the rubber diaphragm (as shown on the piston above) is not torn, common problem with the Stromberg, easily remedied with a new part. Other than that diaphragm they are very similar to SUs in operation and adjustment (the choke is set up different as well I guess). That and check for vacuum leaks.
Have messed with the idle speed adjustment?, screws that adjust where the throttle shaft stops.
SherpaPilot TR6 Strombergs with poor idle Triumph 11
K TR4/4A Strombergs again..... Triumph 7
B For Sale 175 CD Strombergs Triumph Classifieds 0
K TR4/4A Strombergs Triumph 6
sundown TR6 1973 TR6 strombergs Triumph 3
sundown TR6 175cd strombergs Triumph 4
K TR4/4A Replcing the Strombergs with SU's on a 4A.... Triumph 6
B Strombergs Run Rich Triumph 12
K TR4/4A TR4A SU's replacing Strombergs....Linkage issues? Triumph 10
TR4 Settting up the Choke on Strombergs? Triumph 15
K TR4/4A TR4A Strombergs or SU's? Triumph 3
G Lesson learned replacing Strombergs with SU HS6s Triumph 17
glemon Making Strombergs Richer Triumph 22
SherpaPilot Strombergs Running Lean Triumph 18
TRnorwegian Reinstalling the old Strombergs Triumph 2
Phil73 Lotus and Strombergs Triumph 6
Got_All_4 Mixture adjustment on Strombergs Triumph 9
B performance increase from triple strombergs?? Triumph 33
B TR6 TR6 Strombergs Triumph 3
GT6_Mark UK Market Strombergs - Prefix Numbers Triumph 0
mabbott TR6 Rebuilder of TR6 Strombergs? Triumph 11
D Triple Strombergs Triumph 15
G Should I be lubricating my Strombergs? Triumph 8
pcanonge Strombergs? Jaguar 11
S Triple Strombergs or Triple Webers Triumph 15
RobT Strombergs and...Bosoms? Triumph 2
Jayrz Goodbye Strombergs!! Lotus 1
Stinky Velocity Stack for Strombergs? Triumph 13
Hegg Strombergs Flooding and won't start Triumph 12
Carlbanan56 MGB Wont stay runing MG 4
T TR6 Perfectly tuned TR6 wont start when hot. Triumph 11
M Spridget wont start Spridgets 50
K Left my key on for 5 hours and wont start, UGG!!!!!! Austin Healey 48
J TR6 Wont Start Triumph 10
S TR2/3/3A Frustration has started but car wont. Triumph 4
K TR6 Engine Dies and starter wont turn over Triumph 4
Tinkerman TR2/3/3A 60 TR3A wont start??????????????? Triumph 7
glemon TR5/TR250 Turn Signal Wont Blink Triumph 1
C TR5/TR250 Car wont accelerate Triumph 6
T TR2/3/3A new rear brakesshoes wont fit Triumph 10
S MGA Cleaned engine compartment on MGA - wont start now MG 9
T seat Belt Buzzer Wont shut off Triumph 5
R Wont Go Into Reverse MG 6
tri_carb_healey float bowls overflowing/ wont start Austin Healey 5
Newkie Car wont start sometimes MG 8
M 78 Midget Seat Wont Move Spridgets 20
M Seat head rests;...It wont go down? Spridgets 7
rlandrum TR2/3/3A TR3A Engine Wont Turn Triumph 52
Newkie Headlights wont turn off! Hellpp MG 25
Newkie Trunk lid wont close... MG 13
