bmurphy7369
Hello to all,
I finally started the '75 XJ6C with the rebuilt Strombergs back to auto-choke, and have fuel dripping heavily down the front (air cleaner box mounting area). Strangely it is coming from a port hole above the air intake where you can see the needle and piston. Any idea as to the cause of this and how to correct it? I haven't yet installed the air cleaner housing, I did seem to have the leak stopped a few days ago, then hooked up the coolant lines to the chokes and adjusted the idle when the car warmed up. I started the car again last night and the fuel was again pouring out heavily. I decided to give up for the night and seek some help from those more experienced with the quirks of the 175CD2SE's, though I understand they are relatively maintenance free if in good condition. I'm baffled and any help would be appreciated greatly.
Hope you all have been well!
Thanks so much,
Brian
Thanks so much,
Brian
