Stromberg 150 cd vs. cds vs. cdse
Flinkly
ok, so over the years of gt6's (and all cars with strombergs i'm sure), they changed the carbs several times and i was wondering if there was any real benifit to getting an earlier carb for increased tuning ability.
i've heard that the cdse carbs have less options to tune the carb (to help emmisions), but i've never seen anything but a cdse so i don't really know what i'm missing.
70herald
The later ones have all sort of extra stuff added to them mostly to control them when they are cold. Stromberg's aren't really the most tunable carbs in any case. Mostly because there isn't the same range of needles available for them as for the SU's.
The real "advantage" of the earlier units is that they are somewhat simpler.
jdubois
I believe these are the main differences:
CD: Uses a machined bar for cold start that restricts air and lifts the main piston when choked.
CDS: Uses a separate metering needle for cold starts instead of the bar.
CDSE: Same as CDS, but adds a temperature compensator, throttle bypass valve, idle trimming screw, and a leak balancing screw.
rotoflex
Not a separate metering needle, but an assembly called a "starting box" that's a simple setup of a plate with different-sized holes in it. It works well, as well as you need for a choke, compact, simple.
The only carb I can think of off the top of my head which used a separate needle were the SU's with the auxilliary electric starting carburetor.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]CDSE: Same as CDS, but adds a temperature compensator, throttle bypass valve, idle trimming screw, and a leak balancing screw. [/QUOTE]
Except for the needle originally supplied, the CDSE's additional emissions stuff pretty much only affects tuning & operation when cold & at idle (remember, these were early emissions regs they had to meet).
The CDS & CDSE setups are easier for choke connection & operation. The CDS & CD adjust mixture via an assembly at the bottom of the carb; the CDSE via a tool inserted through the top of the dashpot.
Not really enough la difference between the three to vive at.
R GT6 Carb Floats for Stromberg 150 . Triumph 5
TR6BobNF General Tech Midget Stromberg 150 Adjustment MG 8
F Spitfire Spitfire 1500 - Stromberg CD 150 Question Triumph 9
T Stromberg 150 CD carb question Triumph 4
T 150 CD stromberg spraying gas HELP Triumph 6
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
Celtic 77 MGB 77 Stromberg issues MG 12
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
Quackedo TR6 1969 TR6 Stromberg 175 CD-6 Triumph 1
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
S TR6 Stromberg Bypass Valves - Question Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
M General MG stromberg carb MG 5
Sarastro TR4/4A Stromberg linkage question Triumph 4
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
D Stromberg Dash Pot Screws Jaguar 3
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
steveg Online SU and Stromberg needle database with comparison charting Austin Healey 2
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
bfitz Zenith Stromberg O ring question Other British Cars 8
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
K TR4/4A Stromberg question. Triumph 13
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
M TR4/4A Stromberg CD175carb query Triumph 7
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
M TR4/4A Stromberg ? Triumph 4
L zenith-stromberg carbs Lotus 11
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
G Stromberg cd150 question Spridgets 1
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
W Weber/stromberg air cleaners Jaguar 3
dklawson Early Stromberg Floats - 150CD Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
W Zenith stromberg carbs Jaguar 3
J stromberg float source or x referance Triumph 2
L Stromberg 175 cd question Other British Cars 5
D TR6 76 TR6 Stromberg Air Valve Triumph 2
H Stromberg Carb Sync and adjust Triumph 6
T Stromberg Triumph 22
sundown 175cd stromberg carbs Triumph 4
JPSmit Stromberg Carb Question Triumph 15
R TR4/4A Tr4a, Stromberg float setting Triumph 6
regularman I found the fix for the stromberg on the 1500 Spridgets 6
