TR2/3/3A Street cam again and Valve gap?
karls59tr
Bronze
Could someone who is familiar with camshaft speak advise me on what valve gap I should be using with this cam. Here are the specs as written on the bill
M518 Cam...duration 227" @.050"(280"advertised).....280"cam lift....420"valve lift on 109"Lobe C/L
I've been running this cam for years and the engine pulls strong but I've just kept the valves gapped at the stock .010 ......I think I researched this years ago as I found a piece of paper where I marked down to set the intake and exhaust to .016? Anyone knowledgeable in these things think I should open up the gap to .016? Anyone running a similar cam on their TR3?
glemon
Many times they recommend a slightly larger gap with performance cams, but I have no idea how this is arrived at or calculated. I might open up the gap a couple more hundredths and call it good if I didn't have the specs that were provided with the cam (if any). But that is just a shade tree mechanic aw shucks golly durn approach, maybe others can provide a more precise answer.
K
karls59tr
Bronze
So if I opened up the gap by another .004 would the there be a noticeable improvement in performance? Would I have to make timing and carb adjustments? Should I leave well enough alone?:eagerness:
martx-5
I have an Erson 149 grind (from British Frame & Engine), and it has figures very close to yours and the recommended gaps are 0.016" (intake) and 0.018" (exhaust). I also have a list of almost 50 TR3/4 cam specs, and all of the non-stock ("performance type") cams have increased valve gap specs, anywhere between 0.012"-0.022". Unfortunately, my list does not include a cam of your exact specs, but all of the similar cams have valve gaps listed between 0.013"-0.018". I would go with the info on that piece of paper...0.016". There's a reason you have it.
TFB
I am no cam expert but with my old motorcycles and sometimes unkown various high performance cams I usually go by the hot clearance.All the specs are cold clearance for the obvious reason of ease of checking and adjusting,but the end goal,I believe, is minimum clearance at maximum temp.So a quick check of a couple at temp shoud give you an idea if they are to tight.Too loose you will probably hear.
Tom
poolboy
Should you or shouldn't you ?
Take this into consideration. The larger the gap, the longer the valve will rest on it's seat. The longer on it's seat, the more it can cool down. That's an important aspect especially concerning exhaust valves.
K TR2/3/3A Mild street cam and Idle? Triumph 13
TR3driver TR4/4A New "hot" street cam for TR2-4A Triumph 8
K TR2/3/3A TR3...Mild street cam....valve gap? Triumph 8
Basil Across the Street Spotted 2
N For Sale 1964 Triumph TR4 street racer Triumph Classifieds 0
Jim_Gruber Thoughts on stock '69 1275 manifold vs LCB Headers for street use Spridgets 9
Gliderman8 Falcon on street in Boston Spotted 11
Boink It's probably noisy on the street... Rover / Land Rover 0
BoyRacer Best street tires for early 3000? Austin Healey 21
S Best air cleaners/ filters for street Spridgets 8
H best street pads Austin Healey 6
G More low end and milage street 1500 Spridgets 11
B TR2/3/3A Street Roll Bar for TR3 Triumph 12
nissanite TR4/4A TR-4A FI street engine on the dyno at JB Racing. Triumph 36
Russ Austin Ballet in the street, what a treat! Triumph 7
aeronca65t Street Legal! Other Cars 8
Jer Google Street View Spridgets 7
M 1275 street peformer, any hot rodders Spridgets 21
1 07 Triumph Daytona 675 converted to Street Triple British Motorbikes 5
L Street Tire size for 60 spoke wheels Austin Healey 15
Team_Sprite A happy little street car pops up again Spridgets 5
aeronca65t Street Racing-Poland Racing 2
Jayrz Auto-X/ Vintage race/ spirited street ride height? Spridgets 14
kcbugeye1275 Street bugeyes on Ebay Spridgets 3
T Crypt Car dies in street Triumph 17
G Street tires for the Midget Spridgets 17
D Racing equipment helpful on street cars? Racing 10
S TR2/3/3A TR3 on the street for the first time in 10 years Triumph 9
DonPete3 Street Legal? Spridgets 2
Simon TR4a MGB MGB on my street MG 12
M TR4/4A Ebay TR4 spotted by chance on the street! Triumph 0
aeronca65t Rare Costin street coupe Other British Cars 5
Y Street names Sunbeam (Rootes) 2
C Reasonable power out of a good street B motor? MG 15
S Why is this car not street legal ? Lotus 3
J TR 4 Norris Cam 342S Spec Sheet Racing 1
PAUL161 T-Series Crane Cam MG 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
M MGA RHD twin cam steering pinion MG 0
D Cam Timing question. Spridgets 11
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
S TR2/3/3A Replacing the cam shaft Triumph 27
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
Got_All_4 TR5/TR250 Cam and Lifter Problems Triumph 13
B Installing cam bearings 1275, can I do it? Spridgets 1
B Anyone have a Europa Twin Cam for sale? Lotus 6
J TR2/3/3A Confirming Cam Set Up Triumph 5
