JCL TR4
I am repairing my wrecked TR4 race car and have run into a problem with the LH inner fender fitment. I cut off the old inner fender which was torn up after the wreck and found a front end from a TR4 of the same year and drilled out all of the spot welds on both cars. The inner fender fits well except that the front edge where the upper valence attaches is and inch and a quarter lower than the RH side.
The frame was straightened, and is in very good shape with equal measurements from the floor on each side. I can almost measure any part of the car (frame and body) and get equal measurements on each side. But this inner fender does not measure correctly. I didn't even notice it until I tried to put the upper valence in and could tell it was lower on the LH side. I have not welded the inner fender on yet as it is going to require me to raise the front of the fender 1 1/4 inches in order to get it level. That would require me to put a large spacer under the front mounting point to the frame which makes no sense at all.
I am measuring the flat area at the tip of the inner fender to the ground, both on jack stands and on the tires. The frame is perfect. You can see where I am measuring it, and the left side is 1 1/4 higher than the right, at that point. I need to take it back to the frame shop and see if he has some idea. I wonder if the footwell is pushed in, but I don't think that explains it either. It actually looks OK.
I wondered if any restorers on here might have some idea.
Thanks
Thanks
