Discovered something very strange. A few days ago I put a little LED light in a wall sconce. It gives off a bit of light which is all I need, but strangely enough, when I turn it off it continues glowing, not on, but still slightly glowing.
So I checked voltages and discovered that there is 12v on the lamp even when turned off. Then I unplugged the LED lamp and the voltage on the circuit disappeared!
This was interested so I took a look at other bulbs on the same circuit and found that there was 45v (live side turned off to 0) across a CFL on the same circuit. When I unscrewed that bulb the voltage also vanished.
Since it the voltage vanishes when the bulb is disconnected I don't think it is a short?
The only thing that makes sense is that there must be inductance from the live wire in the same conduit, but how does it cause such high voltages, and enough current to partially light the LEDs? And how can I turn those LEDs off, it bugs me seeing them half on.
