Strange Clicky/Tappy Sound
Musicman
Hello to all -
My TR-6 just started making a clicky/tappy (please excuse the adjectives to describe sound) sound. It sounds like it's coming from under the valve cover. In general the car runs great - never any motor issues. The motor was always a tiny bit on the noisy side, however, never to any extent that would raise any red flags. Could this be something simple like a needed valve adjustment? My mechanic will be checking it out hopefully tomorrow. I'm praying to the Triumph Gods that it's not anything really serious.
Any advice and feedback is greatly appreciated.
Dave
poolboy
For a start, I think you're on the right track. Remove the Valve Cover, see what that reveals, then check the valve lash.
If nothing simple sticks out as the source of the noise..then..never mind, cross that bridge if you get to it.
M_Pied_Lourd
First thing I would do is check the oil level. Then , off with the valve cover for inspection to see if anything looks out of the ordinary. As PB mentions, next step would be to adjust the valve lash. After that....
Cheers,
M. Pied Lourd
Musicman
Musicman
Oil level is good. And I also replaced the plugs, points, condenser, rotor and cap. Please excuse my not knowing this but what exactly is the valve lash?
Dave
Geo Hahn
Valve lash is another way of saying valve clearance. Checking/setting this is a simple task -- possibly time consuming the first time as you acquaint yourself with the routine, but well within the abilities of a novice mechanic.
Musicman
Musicman
Many thanks to all for your advice and insight. Thankfully the shop I trust my car to is run by extremely knowledgeable and honest people. They've been taking care of my Triumph for 6 years now.
I'm keeping my fingers crossed that this will be resolved quickly and without the outlay of many greenbacks.
Dave
Vargus TR2/3/3A Strange dents Triumph 19
nicko Strange Engine Noise Austin Healey 7
jlaird MGB Strange daily question. MG 10
C MGB strange?? MG 3
J TR2/3/3A such strange thread on gear shift knob Triumph 12
7 Strange A/C - radio problem Other Cars 7
S TR2/3/3A Strange part Triumph 3
steveg Strange gasket pieces Austin Healey 5
steveg Strange Oil Leak Austin Healey 7
D TR2/3/3A Strange hole! Triumph 5
SherpaPilot Strange Noise While Cornering in TR6 Racing 3
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
Michael Oritt Strange debris found in sump Austin Healey 19
F TR2/3/3A Strange Loud Noise Triumph 11
C Strange...can won't start and then magically ressurects Austin Healey 16
bighealeysource Strange problem with throttle staying open Austin Healey 6
D TR2/3/3A Strange Transmission Issue Triumph 9
Rhodyspit75 Strange windshield washers Spridgets 0
tahoe healey strange OD question. Austin Healey 9
andrea Very strange austin healey 3.9 Austin Healey 5
M Strange Healey Tach Austin Healey 9
Rut Strange occurance! Spridgets 19
aeronca65t Big Healey-strange wheels Austin Healey 12
bighealeysource Okay, here's one with a strange noise from the engine Austin Healey 7
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
J TR4/4A Strange question that may involve the coil- Triumph 13
jlaird Todays strange question Spridgets 6
JPSmit What is that strange grinding sound in the distance? Spridgets 3
PAUL161 MGB Strange Reminder of a Missing Friend. MG 4
B Strange rear light Other British Cars 6
KVH Strange Sound Like Compressed Air Escaping Triumph 14
Bremer TR2/3/3A TR3A: Strange brake bleeding behaviour Triumph 4
B SU Carbs have strange vacuum fitting Triumph 17
Kleykamp TR2/3/3A Strange TR3 side curtains ??? Triumph 13
HAN8L1965 Strange event ? Spridgets 6
T strange litter Triumph 5
aeronca65t Strange and interesting MGs MG 3
PAUL161 Strange 5 Speed Conversion - Will it Work? MG 41
W Strange occurence Spridgets 5
P Strange clunking noise Triumph 20
bugedd Strange trans noise Spridgets 7
SilentUnicorn Strange things British Motorbikes 4
Bremer Strange, but interesting... factory blunders? Triumph 8
M another strange bugeye on ebay Spridgets 12
JAV strange noise Austin Healey 4
J Strange electric problem. Jaguar 11
racingenglishcars This is a strange one! Spridgets 9
A I noticed something strange FORUM Help 4
G Strange Engine Noise...? Austin Healey 20
bcliff Strange rumble/hum MG 13
