100DashSix
Well, this seems to happen to me every two years. This time I was driving on the highway when the engage point for the clutch suddenly dropped near the floor--though the pedal itself felt normal. I was able to shift, but it became progressively harder to synchronize the gears. I was unable to shift entirely, and was only able to get into third gear with some revving and grinding. I was luckily able to guide the car off the highway, through two green lights, and into a parking lot--right across from my building.
The fluid level of the clutch master cylinder didn't drop, and no drops of fluid appeared to fall from the slave cylinder when I put a towel under it and actuated the clutch a number of times. My tools were limited, so I placed a guitar pick on the top of the slave cylinder push rod and actuated the clutch. It fell off, indicating to me that the clutch fork is being actuated--though perhaps not far enough. The clutch pedal feels normal and stiff, not spongy, not mushy, not weak, etc.
Perhaps the clutch has stuck to the flywheel, and the springs failed to push it off? Can that happen? I should've banged on the side of the bell housing with a tool. Any advice?
