Morris
Ugh... for some reason I am just not getting this. Geometry was the only class I made a C in in highschool. Maybe that has something to do with it.
Using my dial, I have found and marked TDC. I have also aligned the marks on my cam. But when I turn the crank, none of the readings I am taking from my degree wheel make sense to me.
According to Kent, my lobe centers should be 112. Does this mean that if I start at TDC before the intake stroke, my dial (which is following the intake lifter) should be at it's highest point at 112?
Is Hap telling met that if I advance that by a few degrees, I will get better performance?
Hi Guest!
