I am working may way through the trouble shooting chart for no spark. I have 12 volts at the coil so I am to beleave I am good from the key to the coil? next step is to see if there is any spark out of the coil, I've read that if I hold the HT center lead to the coil about 1/4" away I should see spark. Here's the problem, I usualy work on the car alone, no one to crank the engine while I look, next I am leary of holding onto the HT lead. Here's my question, maybe obvious maybe not. Could I just hook my timing light pick-up to the coil HT lead while I crank the motor over? I can squeeze ther trigger and turn the key at the same time and not worry about that possible shock, I get that same feeling doing that as when I used to shut down a gas motor with a grounding tab! Not so good. Thanks for the help. /ubbthreads/images/graemlins/cheers.gifMACK
