I've got a '65 BJ8 with a steering issue I can't seem to resolve. It's recently received a new steering box, and pretty much every moving part in the front end has been replaced with new items, including swivel pins and bushings, top trunnions with adjustable innards, tie rods and ends, bearings, etc. An alignment was done and tire pressures are even. After the box was installed but prior to all the other work, I experienced an issue with the steering "tightening" while driving. That is, the car would steer fine at first, but after just a short while, something would bind such that I'd lose all return to center, and turning the wheel would become more and more difficult. I replaced the swivel pin bushes as one was noticeably loose, thinking that would solve the issue. The other work followed that since it was all apart anyway. Still, the problem persists, leading me to think it's something with the box. I've moved the adjuster several times, trying everything from about 1/4 turn out to even 2+ full turns out, all with the same binding. I cleaned out the box and replaced grease with fresh Penrite. All fasteners are tight, and I don't see any odd movements of any components while turning the wheels. The steering has always turned freely and easily when the front is in the air, with no strange noises or binding at any point.
I'm at a loss as to where to go from here. Could the steering arm be somehow creating a bind in the box when the suspension is loaded? Could it be that the box installer added or deleted some shims/washers incorrectly? What else should I check?
Hi Guest!
