I just rebuilt my 7/8" MC with a Moss rebuild kit. Bores are in great shape. No grooves or ridges. I honed and polished the cylinders. Clutch side works flawless.
After I rebuilt I noticed the brake side piston seemed a little sticky. Put a little more fluid on both sides of it for lube and ran it back and forth several times and it seemed better. It sat for a few days before I got a chance to try to reinstall. Ran it back and forth to check and the brake side stuck again. I took it apart to make sure I hadn't missed something. It all looked good. Put it together and it was a little tight but not bad. Installed on car, bled brakes. Now the brakes work great. ONCE. Then the cylinder hangs for a bit and then eases back to fully open.
I know I have seen a thread about this on some board, but haven't been able to find it. Any thoughts on this? Think it will work itself loose with a little use?
Thanks,
Kris
Thanks,
Kris
Hi Guest!
