I posted earlier about the clutch sticking after I replaced the clutch assembly. After reading the article at Buckeye I pulled the transmission to check things out.
The sleeve slides easily on the front cover using the fork and linkage. There does't seem to be any excess friction in any position. I have not yet measured the clearance. Both ends of the sleeve have a small bevel so I don't think sharp edges are a problem.
I was looking at the clutch assy in the Brinkly manual and was wondering how far the throw out bearing actually moves. It does not look like it would be enough for the tilting mentioned in the Buckeye article to be a problem.
Any thoughts or ideas on what to check next? I would really hate to put everything back together and stoll have the same problem.
How is the best way to pull the transmission? I know the way Brinkly says but I need Specifics. Is it better to use a jack, engine lift or something else. I got the transmission back using a transmission jack but I am not sure that was the best way
