Hi folks. I'm still sorting the new TR6 and I'm stuck on an issue.
When I start her up she idles fine until you hit the throttle and the she jumps up to 3000 RPM and stays there. All of the linkages appear to be working ok, and I traced the problem to the throttle body. When you manual open the left carb throttle using the throttle level (#54 on Moss link below). The level will more freely a couple of times but then bind open. The action feels notchy.
Do you think the throttle shaft (#38) is toast, or could the throttle disk (#39) be hanging on something?
Do I need to pull the carbs to diagnose?
Link to Moss part numbers referenced above;
https://mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=32750
Hi Guest!
