Webb Sledge
Three questions:
1: I recently replaced my old Alpine tape player in the 6 with a Pioneer cd unit after the power cable got wrapped around the exposed drive shaft while pushing the car out of a garage and ripped to pieces. Besides the speaker and antennae wires, there are 3 others I'm concerned with: constant power, which I've got coming straight from the battery, unfused like it's supposed to be, a ground which is hooked up, and an accessory wire that would be getting power when the key is in the ACC position, which my ignition doesn't have. I hooked up the ground and the power from the battery properly, but the thing still won't come on. Do I need the ACC wire hooked up to the ON position on the key (rather then ACC, since it doesn't have an ACC position), or should it work off the battery alone?
2: Took the 6 to school today, got in, and the left headlight decided it didn't want to work on low beams, but it did work on high. Is this just a worn out lamp like I suspect, or should I be looking for a disconnected ground/power wire?
3: My amp gauge goes crazy on me every once in a while. It flicks back and forth like I had a turn signal on, but instead of moving 1/8th of an inch, it's swinging way across the gauge without a signal on. It seems to do this more often on left turns... /ubbthreads/images/graemlins/crazyeyes.gif I'm thinking it's a faulty flasher unit, since I hear clicking like the signals make whenever this happens. Thoughts?
