I'm thinking of tackling my steering wheel issue now that I'e decided to replace the stator tube I may as well do that at the same time. Here is the story: One winter a few years ago I pulled the steering box out and brought it inside on the bench to take it apart. I found that the worm gear had a few pieces missing but I did have a spare shaft with a good worm gear. I replaced the adjuster peg as well that goes in the shaft Inside the box I found a bearing that did not look stock but appeared to very similar to the original....I guess the PO ;who had been in there before me, found that the original bearings were not available. I see that Moss now has them if I rebuild again. I left that non original bearing in there. I am not 100% certain I got the end float right??? Anyway the issue now is the car tracks straight when I take my hands off the wheel with little wander. Problem is you can wiggle the wheel from side to side about 3" to 4" and from reading previous posts about this it should only move about 1.5 to 2". Also when driving straight ahead the wheel is off center about 8 degrees. Tried centering a few times with no luck. I read in one of the posts by John on here that It's better to get the wheel centered with the front end components disconnected. I will try that. Is it possible to install the steering box arm (pitman) onto the box in the wrong place? Does the end float affect slop in the steering wheel in any way? Can the box be disasembled in place with front cowl off if I want to take it apart to install a new bearing or am I further ahead to have it on the bench. Any advice welcome. Karl
