glemon
My TR250 has very weak to no return or self center for the steering. Nevertheless it tracks straight and things seem to be fine with the front suspension and steering other than that.
I have adjusted toe in and camber with fairly simple but accurate home made tools, but not sure how to measure caster. So couple of questions.
Is the vere weak self centering normal for 4A-6? I should mention I have wide (205/60) tires and 1/4" spacers on the front wheels.
Second, some forums have suggested there is not an easy way to adjust caster on these cars. Wouldnt swapping a lower a arm shim from front to back on the suspension mounts on both sides adjust caster?
Thanks in advance for any experience/input.
