I just finished rebuilding my engine, and I'll soon report step by step for whatever value it may be.
But in the meantime, I have a nasty rub going on between the steering rack and the fan extension. I just installed new motor mounts so this is puzzling.
If I jack up the engine to put washers beneath the engine foot, do I need to drain the radiator and remove the hoses? All that over again? Disconnect the throttle bar again?
About the cause, I really can't imagine, but two things come to mind: a) maybe I didn't torque the U-Clamps enough? I doubt that would cause this; b) was it proper to slide the rubber steering mounts under the steering rack feet? It looks like that is supposed to be done, but maybe not?
Thanks.
Thanks.
