Hello,
I am trying to take apart the inner tie rod ball joints on my 66 sprite rack I have them unscrewed from the rack main pinion bar, but cannot get the cup off of the threaded cup back. It is obvious a million years ago there was a couple of special wrenches.
Any idea how to undo the ball cap. Yes I have the lock tabs up, I looked in the Moss cat the whole assembly is expensive, 144.00 per side. The ball end joints are a little loose, really not to bad, just wanted everything tight and new.
When I do get them a part I wonder if I can tighten the ball/cap, the shims are not available
Thanks Phil
Thanks Phil
