My main worry ... being sure I remembered to tighten everything I loosened back down. When I think I am done I put a wrench to everything one last time to make sure it is tight.
I share this worry! I bought some of that blue paint from McMaster Carr - "Cross Check Torque Seal". I use this in critical areas; i.e. not the oil drain plug, but definitely on components that will hurt me if they fail at speed. Quick dab does the trick. Does not need to be neat!
