I am replacing all the 40 year old bushings on a 66 BJ8. Front steering arms and spindles are removed. I need to get the idler arm off the splined steering column. 2005 post says to remove the steering column, radiator and grill. Bently book provides instructions. I want to replace the oil seal and bush just above the idler arm. Is there a puller that will work without removing the column. None available from Moss. Small gear puller didn't fit well and fabricated puller did not budge it. Arm has slight movement left to right but will not come down. Any experience, good or bad, is welcomed.
Gary H
Gary H
