steering column grounding strap
doughairfield
Can someone tell me where that braided steering rack assembly grounding strap grounds to on the frame?
Brosky
Down at the bottom of the column at the steering rack. There are two black wires that come off the top of the rack and feed back into the harness on the left inner fender well. Look at the bottom u-joint and ahead of it you will find the wires.
Geo Hahn
On the TR4 a braided ground strap goes from the steering rack to one of the u-bolts for the steering rack mount. Under the inboard nut that is under the mount.
doughairfield
doughairfield
ok, thanks, next time I take better notes when I take the car apart.
Geo Hahn
KVH said:
Geo, where on the rack does it attach?
I think it goes under the nut that you remove and insert a zerk fitting to grease the rack.
Perhaps if one has the solid (aluminum?) rack mounts one doesn't need that cable, but with the rubber mounts the rack needs a ground to enable the horn to honk. Complex but effective.
For the life of me I don't see why they didn't just put a zerk in that hole and be done with it -- but I use the bolt and carry an extra zerk 'cause THTDI*.
*That's how Triumph did it
Andrew Mace
I've long assumed that someone in the Accounting Dept. of Leyland Motors determined that they could save a pence or two per car; presumably the brass plugs were ever so slightly cheaper than "zerks"?
drooartz Of horns and steering column grounding Spridgets 16
olarson TR2/3/3A Steering Column Bracket Triumph 2
M Midget steering column Spridgets 3
B Steering Column Wiring/Sealing Austin Healey 1
Walter74 Steering Column Felt Bushing Austin Healey 3
D Steering Column Adjustment Collet Austin Healey 8
Retired2020 TR250 steering column bushing Triumph 2
ActionJackson Spitfire Steering Column Lock Triumph 3
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
R TR2/3/3A Replace wiring harness in steering column Triumph 61
R TR2/3/3A Install new wiring harness in steering column Triumph 16
R TR2/3/3A Steering Column Wiring Triumph 18
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
R TR2/3/3A Wiring from the steering column Triumph 7
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
D TR6 Replacing Horn insert in steering column Triumph 11
L TR2/3/3A Upper steering column bushing Triumph 8
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
steveg Steering column steady brace and scuttle shake? Austin Healey 2
T TR2/3/3A Is there a Delrin bush available for the top of TR3 steering column instead of felt? Triumph 8
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
T Steering Column Installation Spridgets 6
C Non-Adjustable steering column questions Austin Healey 14
BoyRacer Steering Column Height Adjustment on BN2 Austin Healey 1
SherpaPilot TR6 Steering Column Loose Triumph 8
John_Mc TR6 Steering column rubbler coupler Triumph 8
R TR2/3/3A Installing wiring harness in steering column Triumph 59
B Steering Column Bushing Austin Healey 2
S TR2/3/3A steering column through the body tub Triumph 5
S TR2/3/3A steering bracket that fits under the dash for the end of the column Triumph 2
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
G Steering Column Mounting Austin Healey 1
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
B Outer steering column connection to the steering box Austin Healey 6
D TR2/3/3A steering column bushings Triumph 8
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
D BT7 adjustable steering column / steering wheel Austin Healey 1
G TR2/3/3A Steering Column Support for One-Piece Steering Column Triumph 3
adcronin For Sale MGB New Turn Signal Switches: 62-67 and 68-70 Also 70-73 MBB Steering column cover MG Classifieds 0
rjc157 TR6 steering column Triumph 0
S TR6 steering column bushings Triumph 5
Marvin Gruber BJ8 steering column blanking plate seal Austin Healey 1
J TR2/3/3A Split steering column rubber bushing installation. Triumph 4
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
T TR2/3/3A Steering Column Grommet Triumph 4
D Ajustable Steering Column Escutcheon Austin Healey 2
6 Steering Column Spridgets 6
B Lower Steering Column Bush - Where does it go and how? Austin Healey 14
