Steering Column Cowl
tony barnhill
Great Pumpkin - R.I.P
Simon - I'm still going through my stack...looking for the one with textured top but having problems finding one with good screw areas.
Monark192
Monark192
Tony - Thanks for the update - I thought you had forgotten about me /ubbthreads/images/graemlins/thumbsup.gif /ubbthreads/images/graemlins/thumbsup.gif. Based on the condition of the rest of the car, I would be happy with anything that would more or less fit. The car is for sale as soon as I bleed the brakes and mess up/with the timing.
tony barnhill
Well, I've been looking for "perfect" or as close to as possible...I'll let you know tomorrow
jaybird
There's a RB getting parted out - I can check and get back with you if Tony can't find one.
Rick_Stevens
Me three. /ubbthreads/images/graemlins/smile.gif I've got a matched set (right/left) that are in good shape. Between the 3 of us, you should be set.
R.
tony barnhill
Simon - man do I have them!! 15 complete sets...
But, I found 2 left sides with no right match..one is textured on top, smooth on sides bottom w/round hole for light switch; other is textured all over with square hole for light...tell me which you need & give me an address & I'll get it out today.
tony barnhill
Simon - watch Priority Mail
Monark192
Monark192
Tony - you are quick. Package arrived today and the piece is a perfect match. Thanks
jlaird
Whoooo, another happy customer.
tony barnhill
[ QUOTE ]
[/ QUOTE ]
Yeah, Jack, but for every 100 happy, there's 1 unhappy...
Simon - glad it works!
Rick_Stevens
Cool beans. BTW, Tony - somebody needs to tell Basil it's time for the Barnhill Santa hat to make its appearance. Or maybe a Snoopy avatar. /ubbthreads/images/graemlins/wink.gif That Great Pumpkin thing is still spooky.
R.
mikecyc72usa MGB 1971 MGB Steering column cowl MG 4
budk1953 Steering column cowl question Spridgets 4
Skippy1957 '76 B Steering Column Cowl MG 28
G MGB 78 mgb steering column cowl MG 4
olarson TR2/3/3A Steering Column Bracket Triumph 2
M Midget steering column Spridgets 3
B Steering Column Wiring/Sealing Austin Healey 1
Walter74 Steering Column Felt Bushing Austin Healey 3
D Steering Column Adjustment Collet Austin Healey 8
Retired2020 TR250 steering column bushing Triumph 2
ActionJackson Spitfire Steering Column Lock Triumph 3
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
R TR2/3/3A Replace wiring harness in steering column Triumph 61
R TR2/3/3A Install new wiring harness in steering column Triumph 16
R TR2/3/3A Steering Column Wiring Triumph 18
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
R TR2/3/3A Wiring from the steering column Triumph 7
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
D TR6 Replacing Horn insert in steering column Triumph 11
L TR2/3/3A Upper steering column bushing Triumph 8
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
steveg Steering column steady brace and scuttle shake? Austin Healey 2
T TR2/3/3A Is there a Delrin bush available for the top of TR3 steering column instead of felt? Triumph 8
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
T Steering Column Installation Spridgets 6
C Non-Adjustable steering column questions Austin Healey 14
BoyRacer Steering Column Height Adjustment on BN2 Austin Healey 1
SherpaPilot TR6 Steering Column Loose Triumph 8
John_Mc TR6 Steering column rubbler coupler Triumph 8
R TR2/3/3A Installing wiring harness in steering column Triumph 59
B Steering Column Bushing Austin Healey 2
S TR2/3/3A steering column through the body tub Triumph 5
S TR2/3/3A steering bracket that fits under the dash for the end of the column Triumph 2
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
G Steering Column Mounting Austin Healey 1
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
B Outer steering column connection to the steering box Austin Healey 6
D TR2/3/3A steering column bushings Triumph 8
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
D BT7 adjustable steering column / steering wheel Austin Healey 1
G TR2/3/3A Steering Column Support for One-Piece Steering Column Triumph 3
adcronin For Sale MGB New Turn Signal Switches: 62-67 and 68-70 Also 70-73 MBB Steering column cover MG Classifieds 0
rjc157 TR6 steering column Triumph 0
S TR6 steering column bushings Triumph 5
Marvin Gruber BJ8 steering column blanking plate seal Austin Healey 1
J TR2/3/3A Split steering column rubber bushing installation. Triumph 4
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
T TR2/3/3A Steering Column Grommet Triumph 4
