John, Yes it is a flame sprayed type of process, there is also a hard chroming process that can be used.These services are usually supplied by specialists rather than the usual machine shop. However, if you can machine the fretting out and use a bearing with larger balls to take up the difference this may work too. But the matching bearing race will also require attention ---Fwiw---Keoke
