STEERING BOX SIDE COVER
bj7
I have just received my rebuilt steering box (BJ7) after having it coverted to RHD. The side cover can be used on both RHD and LHD boxes. The only strange thing I have noticed is that the side cover I have now is made of steel and I am sure the one supplied pre-conversion was alloy cast. Was there a change in production at some stage that they changed fron steel to alloy? Is there an advantage of one over the other? The end cover is now stamped 4 56 - does this refer to the year of manufacture ?
"side cover"-???????
Was there a change in production at some stage that they changed fron steel to alloy? ----NO
Is there an advantage of one over the other?---Yes probably stiffness which maintains adjustment.
The end cover is now stamped 4 56 - does this refer to the year of manufacture ?- Can;t say
The "side cover" is the description used in the original parts book. I agree that it is a misleading description.It is the top cover which houses the adjuster with lock nut.
Regards,
Greg
I figured that was what you were referring to Greg. :yesnod:
Like I said I think it is only a minor strength issue.
However, the original cast top may have been buggered up so it could not be repaired by machining and that is all they have available for a replacement.---Keoke
The earlier steering box had the flat steel cover (mine, fitted to BN6L-942) and a marginally faster ratio.
The alloy covered box would have marginally easier steering, and I believe the "peg" is easier to replace.
The new steel top is exactly the same shape as the original alloy one. I will check with the guy who did the conversion and report back.
Well, these pictures should prove that the covers are not directly interchangeable; at least <span style="text-decoration: underline">I</span> can't see how they could be...
1967 BJ8
1957 BN6
Unfortunately, I don't have the same views as shown above for the MKIII, but the arm for the BN6 allows for a flush fitting cover.
Yep,replacing the peg in the alloy covered box is a snap. However, on the earlier box the peg's funtion can be restored simply by forcibly rotating the peg 90 Deg.---Keoke
Somewhat off the subject, how much play do we want in the peg? I just tightened mine to remove all the slack (one to 2 inches play in the steering wheel). Too tight?
TH
TH
A trade off between too loose and too tight; I snug it up until I can feel a drag on the steering (higher effort to turn the wheels) then back of a tad.
TH
HI TH, you should adjust it until you can feel the drag as you go over center.
A good box will show less than 1" of play at the center.
However,most of these boxes are worn and will have more play around center than that.--Fwiw--Keoke
