Hi Guest!
The " Pennrite stuff " from the '60's is like Vasoline . No matter how long you warm it up . The type you use is ? . Just a gear box oil GL-4 ? .The recommended 90 weight will go in through the upper hole, it just takes time. Fill it up, then wait a bit and put some more in. Repeat until it stays level with the hole.
...Fill it up, then wait a bit and put some more in. Repeat until it stays level with the hole.
I use Valvoline Synpower 75W90 (full synthetic GL5 gear oil). In my limited experience, it gives easier steering than grease. Plus, IMO, the main reason they leak is because the brass bushing is worn; which also allows the box to bind under load. Using grease is a band-aid for when you're not willing to fix it right.The " Pennrite stuff " from the '60's is like Vasoline . No matter how long you warm it up . The type you use is ? . Just a gear box oil GL-4 ? .
Depends on which GL5 you're talking about. Some of them (often the cheaper ones) do use an additive that can, over time, break down and damage copper alloys. Actually, some GL4 oils use that same additive, they just don't use as much of it.Is there no danger using GL5 gear oil with brass bushings or is that a myth?
David
I suspect the reason a lot of manuals & lube charts say you must use GL4 is because they were published before there was a GL5 designation - but I could be wrong about that.
I used the Penrite product in my Healey steering box (similar, but not the same as, early TR) it seemed to work well, and stopped a mild leak after I put in new seals. It seems to be getting harder to find here in the States. There has also been quite a bit of discussion of John Deere Corn Head grease as a similar product. I haven't tried it. Similar discussion to this one here: http://www.britishcarforum.com/bcf/showthread.php?93270-Steering-box-oil
