Geo Hahn
Two questions about the Steering Box Adjusting Screw:
1. What does the tip look like? i.e. is it flat or rounded or what?
2. What are the threads?
In case you're wondering why I don't just take it out and look at it -- I no longer have the original part.
Many years ago I went with a modified lid and adjuster that had a spring-loaded pin - the idea (and it worked) was to allow tighter adjustment at the middle w/o any binding at the ends.
Thing is, that pin seems to have failed. The source of the adjustable model required my original box lid as a core, so presumably the hole for the adjustable pin is larger than for the original pin.
My plan it to make a solid pin from a bolt but I am unsure what shape to make the tip. Also, in a quick check at the hardware store, the only suitable size bolt they had was Grade 8 - I assume that would not be a good idea?
Thanks for any sympathy or advice.
The part may be repairable (isn't everything?) but the builder is on his way to VTR so it will be a bit before I know (and darned if I can figure out what holds the works together).
