Steering Ball-Joints
  • Thread starter Thread starter 58_BN4
  • Start date Start date
5
58_BN4
Hello Again, I am again the guy building a car from a "kit". Purchased completely unassembled, with only the forum and catalogs to reassemble. Frustrated by the lack of detail in the Haynes AH manual. I searched the forum and found comments on the turning of the ball joint at tightening, and I believe I have that worked out. Can anyone tell me what the torque values are for all of the ball joint fastenings at the steering assembly? I see an amazing number of things to tighten with no published torque values. Also steering box and idler-arm nuts? With castleated nuts or nylock, how tight is tight? Thanks Agian, don't know where I would be without this forum.
I don't know if there are torque values or not. The ball joints and most of the other steering joints are a taper fit. You are pulling the taper together. Once you do that, you can snug it a little but you do not have to stand on it. If they have cotter pins, I snug it and tighten or loosen until the pin lines up. The manual might show a torque value for the idler arms, but you still have to line up the cotter pins. Hope some of this helps. :hammer:
In lieu of anything 'official' in the manual you can use standard values; e.g.
https://www.portlandbolt.com/technicalinformation/bolt-torque-chart.html
Note that values are usually less if you pre-lube the threads. As always, tap or chase threads beforehand to get a realistic torque reading (or, you can use the old, tried-and-true method of 'torque until it snaps, then back off half a turn').
One of my practices for normal work--where torque specs aren't critical--is to use a 3/8" ratchet with sockets. You generally can't overtighten a quarter-inch bolt or larger with just a 3/8" ratchet with wrist strength.
You'll really want to get a shop manual. The 'Bentley' reprints are faithful, with some additional data. Found one (apparently) here:
https://hdrogers.com/liter.html
One of the sublime joys of owning old British sports cars are the hand-drawn illustrations and droll Brit descriptions in the manuals. The Healey manuals are very well-written and accurate.
