Steel or aluminium fuel tank
Jeepster
I recently decided to tackle the boot area and had a new floor welded in to replace the previous botch job. I also needed to replace the fuel tank and managed to find a second hand one on ebay that looked ok.
When filled with fuel the tank leaked like a sieve!
Well hindsight is a wonderful thing and I wish I had just gone out and purchased a new fuel tank.
My question is -
steel or aluminium? they are both about the same cost and the alu tank will be lighter but has anybody and experience of issues with either choice?
many thanks
Hey Jeepster,
I would go with the aluminum one unless you are trying to be 100% authentic. Those tanks are usually more so if the same, sounds like a good deal.
Regards,
Mike
Well: if you live in a high humidity area or leave your car set up for lomg periods, it might be a 50/50 choice . The water attracted by the alcohol in the petro will attack aluminum causing corrsion as well as causing rust in steel.
I would check to see if there is a local servicer that seals gas tanks and have the one you purchased on e-bay coated.
About 7 years ago my TR7 fuel tank began to leak quite badly. Seeing the cost for a replacement was about ½ the value of the car, I decided to have my tank sealed. The tank was coated inside and out with something (I know not what) that left a solid rubbery surface that was impervious to everything. To date, the car has experienced both active driving and long periods of hibernation without any further problems.
Ray (64BJ8P1)
Ray (64BJ8P1)
I have used the company "gas tank renu" before on a Porsche 911 and it is like Ray says, it had a rubbery like inner coating.
Aluminium but make sure it's large enough for some extra range!
I installed an aluminum tank about 13 years ago and have not had any issues. The orginal steel one took 40 years to rust through.
