blkcorvair
I havent posted in a bit. (new baby) but Im tweaking a few bits with the car soon and have one question. I notice in hard long lefts I suck air in the fuel pump. I can tell because it briefly gets louder. When I make several lefts I can starve it out. Probably getting an air bubble stuck in the pump. (simple facet pump) perhaps a holley pump would perform better? Its a circle track cell and the pickup tube is routed to the back right corner, maybe I shoud tweak it over to the middle? Also run a single HS4 on a stock 1500 manifold (Hap you once talked of defferent bowl angle grommets that would work better with this configuration.) The bowl sits pretty perpendicular to the ground, should it be angled one way or the other? Thanks.
