stretchit2
My wife and I took the BN7 out to visit our kids today (the truth be told we went to see the grandkids). Anyway, during the trip I had a bit of trouble getting the car started. She had plenty of cranking power but she just wouldn't start. The first time I thought I had flooded her, but I was on a pretty steep hill so I just coasted down the hill put her in second and slowly released the clutch she fired up and off we went.
The second time we were in a parking structure (the wife was practicing a little retail therapy) and when I went to start her (the car that is) she had plenty of cranking power but simply would not fire up. I let her set for a bit to make sure she wasn't flooded and tried again, no luck. I then did couple of things before I tried again.
I turned the battery cut switch on and off several times,
I checked the lead from the coil to the distributer,
I removed and replaced the other electrical connections to the coil,
I took off the distributer cap inspected it, wiped it out and replaced it.
When I got back into the car turned on the ignition, pressed the starter button she fired right up.
I should mention that the weather was warm (in the high 80s) and fairly dry.
Does anyone have a suggestion as to what might have caused this?
Jeff
Jeff
