my starter is stuck.....
i took the bolts out and
it doesnt move.....
any tricks to getting it loose?
just clicks when activated....
one of those weeks /ubbthreads/images/graemlins/crazyeyes.gif
Jim, there should be a little square shaft sticking out the front of the starter. (The part towards the front of the car.)
Try turning that and see if it doesn't free things up. It sounds as though your starter gear is stuck in the ring gear.
Jeff
problem solved!
1.take ur common 3/4 inch wood chisel
and hammer it into the top edge between
the starter and the casing till its in
good..
2. pull the chisel out ....starter falls right out!
