I'm going to remove my starter today and was wondering if someone could advise as to the easiest method. Not sure if my problem is electrical or mechanical, but I do know it is filthy at the connections with dirt, oil and acid. Do I need to remove the rear carb? Very difficult to see these connections from top or bottom; either muffler pipes (from below) or carb/intake (from the top) are in the way of making this simple. Any advice to make this simpler would be appreciated. Thank you.
Reid
Reid
