Confused about how to wire the starter relay, problem one, if you hold the relay with the two closest posts to the right for reference, the shop manual labels them as this, top right as C2, bottom right as W2, middle as W1 and left as C, the actual relay is as follows, top right W2, bottom right as C1 center as C2 and left as W1, question, do I wire to position or to the letter and number? Next, the manual calls for C2 to be wired to WN, W2 to B, W1 to WR and C to N, next problem, I can't locate a WR wire, next I have a double solid blue(u) wire (the manual states solid blue for headlights??) this wire goes "hot" when the key is moved to the start position, should this be in place of the WR wire? Long question but anyhelp would be great, Thanks!!
