TR2/3/3A Starter rear plate 54 TR-2
Redoakboo
The power stud at the back of the starter rear plate was stripped. I dis-assembled the starter and removed it from the plate, re-taped the stud and am attempting to put it back together. There is a plastic insert that goes in the plate hole around the stud. Is it on the outside of the plate, or inside? I bought some new insulated washers as the old ones were disintegrating.
Dick
sp53
I looked around for picture but could not find one; it probably does not matter as long as the lug does not touch the case. I have seen it both ways. I would choose the way it would stay in place and function best.
R
Redoakboo
Believe it or not, I had taken a pic of the back plate before I removed it. It shows well that it is on the outside. Duh! Sorry to have wasted your time.
If I ever figure out how to download pic's from Picasa on this site, I could explain so much better "Pic is worth 1000words".
Dick
R
Redoakboo
I am starting to put the starter back together. Is there a secret way of installing the brushes back on to the armature? I tried disengaging the springs first, slipping the plate with brushes back on the armature. Now some of the springs have come off their support and i am trying to re-mount them so there is tension on top of the brush. I finally got one back on, three to go. There has got to be a better way of doing this?
Dick
sp53
Yes---you remove the end of the spring from the holder leaving the brush in the holder then take a small hook tool and pull the end of the spring back over to the holder. There are good pictures in the original repair manual. Randall has posted the book many times; it might be available on line somehow if you do not have one
DavidApp
Hello Dick
What do you use to take your photos?
If it is your phone you can e mail them to yourself then save them to a folder on your computer. From there you can use the "Insert image " icon to add the image to your post.
David
R
Redoakboo
Hello Dick
David
I use a digital camera and down load pic's into Picasa. I can send them anywhere just fine as a email, other then the Forum?
Dick
R
Redoakboo
Now that I have the stud threaded and back installed on the plate, and the brushes back on the armature, how do i re-attached the copper wires back on the end of the stud.
Tried to download pic's from Picasa in my PC, no dice? It said they were to large to process?
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 0
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
edkap2002 TR6 starter motor advice Triumph 12
algot1901 1950 Prefect starter Other British Cars 1
Martinld123 High-Torque Starter Austin Healey 4
R TR6 Starter wiring question Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
B TR4/4A High Torque Starter Wiring Triumph 9
algot1901 1950 Prefect Starter Other British Cars 10
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B High-Torque Starter Rattling Noise Austin Healey 3
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
J TR6 72 TR6 starter problem Triumph 10
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
C MGA Change a pull starter to a push button system MG 6
Michael Oritt Starter Button Austin Healey 19
D WOSP Starter Austin Healey 9
DrEntropy MGB Replacement starter MG 7
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
AUSMHLY Crankshaft Starter Nut Austin Healey 10
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
B TR4/4A Starter dog bolt Triumph 15
D Starter Austin Healey 26
red57 What starter is this? Austin Healey 6
S TR2/3/3A Correct Starter Triumph 4
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
R TR6 Is this a starter issue? Triumph 6
Got_All_4 TR2/3/3A Gear reduction starter problems Triumph 5
John_Mc TR6 Starter not engaging consistently Triumph 9
M TR6 Starter lagging issue Triumph 2
Gliderman8 Starter keeps running TVR 20
B TR2/3/3A Starter catches 50% of the time Triumph 15
K For Sale Starter Hand Crank Triumph Classifieds 0
