hondo402000 said:
could the starter problem be associated with the motor not shutting down when switched off?
Seems unlikely to me. Obviously the starter solenoid is getting enough juice to engage the starter (which for those gear drive things is quite a bit); and power to the solenoid is the only thing that happens inside the cabin. The only parts in common between the two circuits would be the battery cables and the ground strap to the engine. And if the ground strap were bad enough to cause a problem with the ignition, I don't think the starter would work at all.
My suggestion would be to pull a side wire off the coil, and connect a voltmeter directly to the starter terminal and the starter housing. Then jumper the side terminal on the solenoid to the battery terminal to crank the engine, and see how much voltage the starter motor is actually getting. If it's at least 10v and the engine is still cranking very slowly, most likely the starter motor itself has a problem (broken wire, stuck brush, binding gears, etc.)
Or, if you don't have a voltmeter, just pull the wire and crank the motor for 30 seconds or so, then feel all along all the battery cables and ground strap to the engine. If you find a hot spot, that's where the problem is. No hot spot means most likely a bad battery, or a bad starter.
Yeah, I know it's new, but these days new doesn't always mean good. One other thought, is there any chance you got the wrong model of starter ? I think (not certain) that the TR4 starter had a bigger pinion gear but the same bolt centers as the TR6. It might engage but bind ?
BTW, it's possible for battery cables (and wires in general) to corrode or break under the insulation, such that they will no longer carry current as they should but look OK from the outside. Not a common problem, but very frustrating to find when it does happen.
The ignition problem doesn't sound like a bad connection or bad ground to me; but rather something bleeding current into the ignition circuit with the key turned off (possibly the ignition switch itself).
