Joe_Pinehill
I went for gasoline, and when I tried restarting, the starter did not budge, I was able to have the attendent push me and poped in gear and it started right off.
When I got home, I check connections from the key switch, look ok.
Checked solenoid, (it looks original) when i probed both of the high current posts, I got 12 volts without the key in, Is this is a sign of the solenoid pulled in, and chared surface is enough to pass voltage but at low current?
When I used a jumper cable and touched the negative high current solenoid post to the positive battery post, the starter turned.
Ive disconnected the battery and plan on picking up a solenoid. The Moss catalog has an after market for 13 and lucas for 39, is it worth the extra money for a Lucas?
