Bob_Spidell
Odds are it's the solenoid. While battery cables can deteriorate over time, they usually won't go bad all of a sudden (assuming it didn't get damaged somehow).
If you have a carbon pile load tester you could reinstall the battery and load test at the end of the battery cable. If your battery tests good at the end of its cable it's probably (almost certainly) the solenoid.
The original-type solenoid is fairly expensive, but most vendors sell an aftermarket (without the button on the back) one for about $15. You could install one of those and, if it works, decide if you want to spring for the correct one (keeping the aftermarket for a spare).
Hi Guest!
