58Custom
Just as the car began running well and after I rebuilt the tach with Steve Maas' circuit and had the tires rebalanced as best as they could (confirming my vibration problems are due to old wire wheels needing service) a new issue has cropped up.
One day after commuting to work I went to take a package to UPS at lunchtime. I turned the key and the starter motor turned but did not engage the flywheel. I hit the key repeatedly and finally it did engage. I did not have any more problems with it until it happened again once yesterday. This morning I pulled the starter out and took a look at the gear. There seems to be no problems. It moves very easily, the splines (or tracks) are clean and smooth and it's well lubricated. I did add a little more oil but nothing looked wrong. Back in it went.
What would cause the starter gear to not engage?
Hi Guest!
