So Sunday I started my car as normal, but when I released the ignition switch from START to RUN the starter stayed energized. I shut it off and tried it again and it was fine.
Today, I just turned the ignition key and when it got to the RUN position, the starter engaged (and stayed engaged).... I never did turn the key further clockwise to reach the START position.
Could it be the starter relay?
Ignition switch? or
Starter solenoid?
Anyone have a similar problem?
Thanks for the group help!
Note: car is a '73 but it has a '74 wire harness with the starter relay.
Ignition switch? or
Starter solenoid?
