TR2/3/3A starter choice
Dr_Mike
new thread to choose a new starter... see old thread on "stuck"engine for background.
Either I can buy a modern "high torque" starter for $200 or so ( MORE IN CANADA) or I can buy a new" Wilson " starter from FDC in Tucson at about $100 US. It is supposed to be a direct replacement for Lucas 25555 . I have never heard of this product. Does any one have experience or comment about this.
From the previous thread i think my first starter, 25521D. got hung up on the gear ring bolts but I will have to check that. The car came with old style unit (bomb?) , not appropriate for the bolt on flywheel although i know people have used them successfully
Geo Hahn
I have not heard of FDC in Tucson... not a big town so I would have expected to. Can you tell me more about the Wilson starter?
Also - since your came with the 'bullet-nose' or 'bomb' starter - have you confirmed that you have the later style bellhousing to accommodate the long nose starter? I suppose you must as you had one installed but then that one did not work.
Sarastro
Those high-torque/gear reduction starters are nice units; I've had one on my Porsche for a few years now, and I like it. I think I'll eventually put one on the TR4A.
charleyf
And the third choice is to find a used starter from the Forum classified or eBay or such. While rebuilding my cars I had several starters. I took two down to a local electrical motor shop (very reputable) along with new brushes and ask him to rebuild them. I got them back with the new parts still in the bags and the comment that "those starters are in great shape and should last for a long time". And I have them on my 2 TR4's and they are working fine.
Charley
M_Pied_Lourd
Hi Dr Mike,
I went with the high torque starter on my 60. No regrets.
Cheers
Tush
I've been putting high torgue starter on all my cars. I like how they spin the engine over faster, sound I don't like but can live with that.
Marv
sp53
I would at least look into a starter rebuild shop that is local to you. They are not that difficult to rebuild or have rebuilt. The most difficult part is having the armature turned on a lath if needed. Here I can get that done for 30.00 dollars. There is a builder’s trick to getting the 4 brushes on the armature once it has been tested for shorts and turned, but it is a simple trick done with a hook and the bushes outside the case.
steve
Dr_Mike
Sorry, my reply got lost.having computer difficulty too.
Seems like they(FDC) have just relocated to Tucson, whence i do not know. I think their website is <apartsdepot.com>. But Wilson has a widespread dealer network, including on in Canada. Yeah!
I think they mention 5 Different versions of 25555 ( A-E) with the same substitution doing for all. Not confirmed.
I have the regular , undamaged, bolt-on flywheel.
Let us hope this goes!
DavidApp
I went with the High Torque starter as the one that came with my car had a bent shaft.
Got it from British Starters. They wanted to know the style of starter ring gear on the car and the number of teeth on the ring gear so they could supply thee correct starter.
David
Jim_Stevens
Also went with a modern starter...mostly because of clearance issues with the bull nose starter and my headers. Works great, though.
Dr_Mike
Thank you all, belatedly.
I am trying to keep things "original".
I have been trying to get a starter here in Canada with no success. The best idea is to acquire, somehow, the appropriate pinion and fit it to the starter I have (25521D).
There are a lot of starters with the same motor and layout. Has anyone done this? Moss claim to have a pinion but it is costly. I suppose one could also grind down the existing full length pinion to the right shape--
etc!
Dr_Mike
You would think so, but it looks different from the one linked to it on eBay which shows a ground off half of the pinion. But the number is correct. So has PO messed it up a bit? I think the shaft on the one you showed might get in the way.
Thank you: the lesson is to watch eBay and get what I think will work for me. I can have it shipped within the US and pick up at the border if I have to.
MIchael
groupdeville
Easiest way to determine which starter you need is to check which way the beveled teeth on your engine's ring gear face: generally, teeth toward the front of the car means early-style starter, and toward the rear means the later style starter with the open shaft.
BUT: it is possible for a previous owner to have put a ring gear on backwards, so pull the small metal cover plate behind the oil pan off and look for the presence of bolts holding the ring gear on. If you have a bolted ring-gear, the tooth bevels should face towards the rear of the car and you need a late-type starter. If no-bolts, you have a shrunk-on ring gear and the teeth face forwards, meaning an early starter.
It's also possible for a shrunk-on ring gear to move from it's proper seat at the front of the flywheel toward the rear of the car, in which case it will also have to be re-seated. Check for mangled teeth at the same time you have the plate off.
Dr_Mike
Ring gear is bolted on. Car came (1995) with "bomb" starter which worked. and the ring gear is undamaged, but I have no idea whether it was on for long. As noted, somewhere, the car is a mishmash of parts aka a mongrel! I know some people have used bombs without trouble, but not recommended.
Dr_Mike
found what looks like the correct starter on eBay. Thank you "2long" for the advice. We shall see when it arrives. Hopefully this is the end of this story: there will be others?
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
edkap2002 TR6 starter motor advice Triumph 12
algot1901 1950 Prefect starter Other British Cars 1
Martinld123 High-Torque Starter Austin Healey 4
R TR6 Starter wiring question Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
B TR4/4A High Torque Starter Wiring Triumph 9
algot1901 1950 Prefect Starter Other British Cars 10
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B High-Torque Starter Rattling Noise Austin Healey 3
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
J TR6 72 TR6 starter problem Triumph 10
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
C MGA Change a pull starter to a push button system MG 6
Michael Oritt Starter Button Austin Healey 19
D WOSP Starter Austin Healey 9
DrEntropy MGB Replacement starter MG 7
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
AUSMHLY Crankshaft Starter Nut Austin Healey 10
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
B TR4/4A Starter dog bolt Triumph 15
D Starter Austin Healey 26
red57 What starter is this? Austin Healey 6
S TR2/3/3A Correct Starter Triumph 4
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
R TR6 Is this a starter issue? Triumph 6
Got_All_4 TR2/3/3A Gear reduction starter problems Triumph 5
John_Mc TR6 Starter not engaging consistently Triumph 9
R TR2/3/3A Starter rear plate 54 TR-2 Triumph 12
M TR6 Starter lagging issue Triumph 2
Gliderman8 Starter keeps running TVR 20
B TR2/3/3A Starter catches 50% of the time Triumph 15
K For Sale Starter Hand Crank Triumph Classifieds 0
