TR2/3/3A Starter bushing.
TR3driver
Great Pumpkin - R.I.P
Slow cranking, worse when hot in my case. Seems like it would make a lot of noise, but I didn't hear any.
Eventually of course, it won't crank at all, but I didn't let it go that far.
CJD
Are we talking about the rear bronze amateur bushing, or the rubber pinion bushing in the early bullet nosed starter?
TR3driver
Good question. I was talking about either of the bushings that support the armature. The bonded rubber drive on the early starters is a different symptom entirely.
K
karls59tr
Bronze
In the later starter. Isn't there a bronze bushing somewhere near the front that wears out? Not really too familiar with the inner workings.
TR3driver
Yes, the armature is supported at both ends by Oilite bushings.
Either one can wear out, but the front one might wear faster. If either (or both) are worn badly enough, the armature starts rubbing on the pole pieces and the resulting friction robs power from the motor. There is a very strong attraction between the two while cranking, so it may rub while cranking even if it doesn't seem to rub just turning by hand.
The problem is quite obvious when you get it apart, though. Both armature and pole piece will be partially ground away.
The bushings aren't hard to replace; but ISTR availability was a problem. Last time I went through this, I had to buy some that weren't the right length from a different source, and cut them down. But that was a long time ago, so it's probably different today.
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 0
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
edkap2002 TR6 starter motor advice Triumph 12
algot1901 1950 Prefect starter Other British Cars 1
Martinld123 High-Torque Starter Austin Healey 4
R TR6 Starter wiring question Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
B TR4/4A High Torque Starter Wiring Triumph 9
algot1901 1950 Prefect Starter Other British Cars 10
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B High-Torque Starter Rattling Noise Austin Healey 3
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
J TR6 72 TR6 starter problem Triumph 10
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
C MGA Change a pull starter to a push button system MG 6
Michael Oritt Starter Button Austin Healey 19
D WOSP Starter Austin Healey 9
DrEntropy MGB Replacement starter MG 7
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
AUSMHLY Crankshaft Starter Nut Austin Healey 10
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
B TR4/4A Starter dog bolt Triumph 15
D Starter Austin Healey 26
red57 What starter is this? Austin Healey 6
S TR2/3/3A Correct Starter Triumph 4
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
R TR6 Is this a starter issue? Triumph 6
Got_All_4 TR2/3/3A Gear reduction starter problems Triumph 5
John_Mc TR6 Starter not engaging consistently Triumph 9
R TR2/3/3A Starter rear plate 54 TR-2 Triumph 12
M TR6 Starter lagging issue Triumph 2
Gliderman8 Starter keeps running TVR 20
B TR2/3/3A Starter catches 50% of the time Triumph 15
